Aquacal heat pump temp sensor bad?
I have an Aquacal SQ110. And I believe the temperature sensor is bad. The unit seems to be showing the pool temperature at least 10 degrees lower than it actually is.
Is there a part for this where the sensor can just be replaced?
Thanks.
Good Morning Jerry557,
Hope you are doing well. My name is Robert Brown & I am in tech support at AquaCal.
The best replacement temp sensor part number is ECS0275 & will need to be adapted into the machine.
This is an upgrade to the original sensor & should take care of all your issues.
Please contact INYO pools for you best pricing. If you have any issues with installing, please call AquaCal tech support at 727-456-4711 Mon - Fri 8am t o5 pm for assistance.
Robert
