Hi, my Aquabot turns on but after two seconds it turns off. Any idea on what could be the problem? Let me know. Thanks!
Hello Manuel - That is usually the sign of a bad power supply. However, you may want to troubleshoot the cleaner first. You can use a multimeter to work your way through the cleaner to eliminate certain parts. Check out the video below. We used a Dolphin cleaner but similar steps can be used on the Aquabot.
