I just put my system back together from the winter. Plugged everything in and the pump does not turn on when plugged into the bottom plug of the aqua rite box. I plug the pump into a plug and it works. Checked the fuse inside and all is good. Seems like everything else is working fine. Removed the elec wires from the main board to the plug and tested for power at the main board…nothing. not sure where to look next? It could be the PCB but could it also be the timer body/switch? The LCD works, lights come on, transformer comes on…
Hi Barry, we are sorry to hear about that. Start at page 20 on this AquaTrol Troubleshooting Guide and follow the illustrated steps to determine what the issue is. If you need them, here are links to a new Aquatrol timer, new board (RJ or Return Jet System Board or HP or Hard PVC Pipe Board). Those items are the most likely culprits.
Please keep us updated!
