Aqua Logic Main Board Replacement
Hello,
I currently have an Aqua Logic control board, part number-g1-066008n-1.  I have seen threads where the replacement is the GLX-PCB-PRO but have seen that the GLX-PCB-MAIN may work as well?  Can you please advise if that is the case?  Thanks so much!
Yes you may use either board, if you use the GLX-PCB-MAIN AquaLogic PCB Board then you will stay with the same software as your current AquaLogic system. If you go with the GLX-PCB-PRO ProLogic PCB Board then you will upgrade your system to the newer ProLogic Control System which has the newest bells and whistles within the software. If you just want to keep your system as it is then the GLX-PCB-MAIN would be the route to go. If you think in the future you may want to add on accessories (accessories are at an extra cost) to control your system through your smartphone then you would need the GLX-PCB-PRO. I hope this helps, by the way, currently, both items are in stock ready to ship!
Thanks, Patrick!  I have a Goldline (G1-979001B) remote panel in my garage so I am hoping with the GLX Main, that this remote station will continue to work. Do you know if anything will need to be done after I install the new board?  Thanks again, I am going to order the GLX-PCB-MAIN board from you shortly.
Sounds great, thanks so much! I believe you will need to re-program the equipment through your AquaLogic as all of that will have been stored in the previous board (i.e. pump run times, light turn on and turn off times, etc…)
