On the label right below the 115/230 it says ROT CCWPEWhat does this mean?.AO Smith SQ1102
From the AO Smith pool motor manual:
Rotation (Rot): Rotation is the direction the shaft turns.
Almost all swim pool pump motors turn counterclockwise
when looking at the motor from the end where the
pump is located. This can be referred to as CCWPE.
The CCW means counterclockwise, noit sure what the PE stands for.
Limey69 thanks so much for that information! I also found this in another AO Smith documentation…
Rotation (Rot): Rotation is the direction the shaft turns. Almost all swimming pool pump motors turn counterclockwise when looking at the motor from the end where the pump is located. This can be referred to as CCWPE.
So I think the entire CCWPE listing just means counter clockwise rotation.
