I would like to replace the large pool light bulb in my Anthony pool with a LED bulb, THe pool is approximately 25 years old. which one should I purchase? IT takes a normal base screw in flood type bulb
We’d be glad to assist you. Do you know if your pool light is 12v or 120v?
120V, Thanks
We’d recommend the PureColors LED Bulb. The model number is PL5809. That is a 35w 120v color changing LED bulb.
We would also recommend replacing the gasket when you replace the bulb. The part number for the Anthony pool light gasket is 3510-06.
Thank you
