Hello There is a washer or a gasket to fit around the outer rim of the volute 39501100 do you carry this or at least know what it maybe referenced as?
Hi @Malick Yes we do carry the outer gasket that goes around the American Products Americana volute 39501100. You will need the 39501300 Americana Seal Plate Gasket (key #8) there is also a complete American Products Americana Gasket Kit which includes all the gaskets, o-rings, shaft seal and o-ring lubricant, normally the gasket kit is a better deal. Here is a link to the complete Exploded Parts Diagram for Your Americana Pump which you may want to print up and keep on hand in case you need parts down the road. I hope this helps!
That does not appear to be the one, the one I’m looking for is about 2" goes around the threaded edge on top of the outlet and has a portion in which does inside the hole
Can you post a picture directly to this Post… of your volute… and a couple photo’s of your pump
