Above ground pool top rails
I’m trying to locate top rails & caps for a 24 X 54 round Cypress above ground pool. Here is a description of the pool from a dealer’s website: Steel frame complete with 8.5" steel top ledges and 7" steel uprights.
Any help you can provide is greatly appreciated.
The Cypress above-ground pool comes with so many features and protections against weather wear that corrosion will be the last of your worries. Made with a steel frame complete with 8.5” steel top ledges and 7” steel uprights, the Cypress provides unmatched stability and durability. With such a strong structure and beautiful design, the Cypress brings unparalleled, worry-free luxury to any home’s backyard. - See more at: https://www.greatbackyard.com/cypress-above-ground-pool.html#sthash.UwZ0gX1x.dpufThe Cypress above-ground pool comes with so many features and protections against weather wear that corrosion will be the last of your worries. Made with a steel frame complete with 8.5” steel top ledges and 7” steel uprights, the Cypress provides unmatched stability and durability. With such a strong structure and beautiful design, the Cypress brings unparalleled, worry-free luxury to any home’s backyard. - See more at: https://www.greatbackyard.com/cypress-above-ground-pool.html#sthash.UwZ0gX1x.dpufThe Cypress above-ground pool comes with so many features and protections against weather wear that corrosion will be the last of your worries. Made with a steel frame complete with 8.5” steel top ledges and 7” steel uprights, the Cypress provides unmatched stability and durability. With such a strong structure and beautiful design, the Cypress brings unparalleled, worry-free luxury to any home’s backyard. - See more at: https://www.greatbackyard.com/cypress-above-ground-pool.html#sthash.UwZ0gX1x.dpuf
Hello Starrey44 - We’d be glad to assist you. The steel top rail for a 24’ Cypress is part number 35288. The top cap is part number 10146 and the top cap support is 10159.
