HI guys ; Im getting a IGBT temperature fault code on my model ECM27CU pump control panel. Opening pool for the season and pump will not run , any suggestions.??
Let me get with our Century rep. to see if he has any suggestions on this…
Per Century…
“That indicates an overtemperature of the board which could be a failure, requiring that the motor be replaced in warranty. A broken fan or motor overload, possibly caused by a bad bearing would also cause that fault. The fan can be inspected by removing the cover, and the motor can be rotated by inserting a hex key wrench in the recess on the shaft.”
