Could you help in determining what type of liner I need to order unibead/J-Hook/beaded. Attached are 2 pics. The 1st is inside/2nd outside
THANKS
Hector/ Rob …can you help??
It looks like a beaded liner. You could always order a j-hook/unibead liner to be safe. The j-hook can be removed if it turns out to be beaded or you could remove the existing bead receiver and use the j-hook on the wall.
