Hi, I just ordered an A.O. Smith 1.5 HP Round Flange 56J Up Rate Motor to replace an A.O. Smith 1 HP Round Flange Up Rate Motor that died after five months (two seasons) use. Invariably these die at the worst time, so I upped the size based on INYO support. Needless to say I am concerned that the AO Smith motor will die prematurely based on the poor ratings elsewhere. Can you reccomend a variable speed pump package that I can replace the whole setup with one that is 115 volts (tall order as most seem to be 230v), Inground, 25k gallons, chlorine, heated, North East US. Any assistance would be very much appreciated. Current pump is a Hayward Super II.
Thank You!
