Would like prices
We have just installed a 17,850 gallon inground pool.
We are needing a variable speed pump, cartridge filter, and a salt generator.  Would also like information and pricing on an electric heater.  Can you please send pricing on these items.  We would like a package deal if possible.
Thank you.
Hi Anthony,
Thank you for your post… could you answer the following questions so we make sure to quote you the correct items…
  • What size plumbing do you have?
  • Is this a pool only or a pool and spa combo?
  • Approximately what is the distance from your pump to the main drain at the bottom of the pool?
  • Approximately what is the distance from your pump to the skimmer at the side of the pool (if you have two skimmers supply both distances)?
  • Do you have anything else that the pump powers like water features, solar, etc…?
  • What is your state and zip code?
For the electric heat pump, it is best for us to do a heat pump audit to determine the properly sized unit. Please answer these questions so we can suggest the proper unit.
  • Will this be heating just a pool or a pool & spa?
  • What temperature would you like to maintain? (82 -85 degrees is standard)
  • Do you want to heat the pool year round or just extend the pool season by a few months in the spring and fall?
  • What is the square footage of the pool? (For example, a 40’ X 20’ pool would be 800 sq. ft.)
  • What is the average depth of the pool?
  • Do you have high wind conditions from a lake, ocean or open field with winds over 20 mph consistently?
  • Will the pool heat pump receive direct, partial or no sunlight?
  • Will you be using a solar blanket?
  • Is the pool and indoor or outdoor pool?
As soon as I hear back from you on these questions then I will work up a quote for you with the appropriate items.
