Why Variable Speed
It might not be strong enough to run pool features or a pool cleaner and would take longer to filter all the water.  I am repairing my old 1 HP single speed pump before I spend $1000+ on a variable.  I wonder if it wouldn’t be cheaper to install two single speed pumps, one smaller and one larger than spend what they want on a variable speed.  They sound like they are a pain to use.  (I have trouble setting my sprinkler timer.)  Also be aware that if you install a variable speed yourself, you won’t get much of a warranty from the manufacturer (60 days).  And the savings will only occur during the summer months.  Here in AZ, I can get by only running my pool pump a few hours in winter, and I am on a time-of-use plan where cost is $.0721/kwh hour, ends up to be about $9/month running a single speed 1 HP motor.  I figured I’d only save money for 3-4 months out of the year.  After installation (talked with several pros) and mark up on the new variable speed pump I’ve gotten quotes for $1000 (Pentair 1.5 HP Superflo VS) and $1400 (Pentair 3 HP Intelliflo).  The Intelliflo is what they are all pushing, but, if you don’t know what your doing at set it too high, you could damage your equipment.  I figured I’d also have to hire a pool service at $100/month to change the settings for each season.  The Pentair Superflo VS looks much simpler to operate, but all the “Pros” tell me I wouldn’t save as much in electricity.
In my circumstances, these variable speed pumps would cost me an arm and a leg and have a terrible warranty.  Read the reviews on amazon, read the complex warranty, calculate each month’s electricity costs.
