Variable Speed Pump and Pool Sweep
Hello…I am emailing you from Bakersfield CA as my friend here recommended you.  She also bought her equipment from you and it was shipped out.  I have a 10000 gal pool with just the regular white plaster.  Just a standard pool.  What type of motor and sweep would you recommend?
Thanks for you assistance.
jackie
Hello Jackie - We have a great deal right now on the Raypak 1.65 THP Variable Speed Pump model PS165VSP. This pump would be sufficient for a pool your size. You can view other options on our variable speed pump page.
As far as the cleaner, we recommend the Maytronics Quest robotic cleaner. This cleaner works idependently from your filter system and stores all the vacuumed debris within the internal cartridge system.
For more alternatives, check out our Pool Cleaner Page. Thank you for shopping with INYOpools.com!
