Tune up kit
Which tune up kit would I need for motor USN1152? I’m going to buy a replacement motor but I have another pump that I would like to replace the seals on. My other pump stopped working. I changed the capacitor and it barely ran and was smoking. Is there anyway for me to fix my existing motor or does it need to be replaced? Thanks,
Hi Oblumen,
The USN1152 is normally used on a Hayward NorthStar Pump do you have a Hayward Northstar Pump? Could you post a photo of your pump to this thread?
If you do have a Northstar then you would need this 1.5 HP Hayward Northstar Tune Up Kit along with this Hayward Northstar Seal Plate O-Ring.
On your other pump motor, if it got to the point where it is smoking then 9 times out of 10 you have damaged other internal components of the motor and it would be most cost effective to replace the entire motor. Can you post pictures of your 2nd pump and motor as those would help determine what motor you need.
