Pump issue
I back washed and after putting the valve back in filter mode then turning the pump back on, water continues to slowly fill the backwash hose. What can I do to stop the pump from filling the backwash hose as if I’m backwashing?
Hi JRinney5,
Can you let me know the make and model of your filter, there should be a label on the side of your filter tank, also any information off of the valve would help out as well.
Normally the issue of water leaking out of the backwash port is a bad spider gasket but a bad washer or bad spring in the valve handle could also be the culprit. If you could give us information on your filter then I could suggest a few parts that should fix your problem.
Thanks for the response; your analogy was accurate. I Have someone coming out to replace spider gasket tomorrow
Issue resolved, spider gasket replaced and pool is up and running.
JRinney5, That is great news! Thanks for keeping us posted.
