Pressure relief valve
I have a DE6020 filter, I always have a high reading on the gauge 30psi. I changed the pressure gauge and still reads 30psi. I also replaced all new grids, still no good. The other problem I have is when I open up the pressure relief valve very little air comes out and only a drip of water instead of full force water. At 30psi I still have good pressure coming out of the returns. Any suggestions . Thank You, Anthony
Hi Anthony,
Could you let us know what HP pump you have? Also could you supply a few photos of your equipment set up? This would help us troubleshoot your issue.
