Replacement Motor for Jandy Stealth SHPM1.0 Pool Pump?
We have a Jandy Stealth SHPM1.0 pool pump that needs a motor replacement.  Our pump is Century Centurion/A.O. Smith and has serial number  CB05-31.
Part 7-193992-06.   Type CX   R56Y frame.
There is no HP or SF listed on the tag.
Can you recommend a motor replacement that we can order from you?
Thanks!
The replacement motor for your Jandy Stealth SHPM1.0 is model B2853.
If you can provide the serial number from the pump housing, we can recommend the replacement shaft seal. The serial number would look something like P08FF0001.
