I am needing a replacement for my pool pump but can’t seem to find the exact one. I now have a Waterway Hi-Flo II 48-frame above ground 115V 2HP dual-speed. It has a part #PH2200 – 6RP. It is making a loud whistling type noise and the neighbors are becoming annoyed . Can anyone suggest a replacement and where I can order one? Thanks so much!
The exact replacement would be Waterway model PH2200-6R. This is a special order pump and the lead time is 3-4 weeks.
Pool pump is a critical bit of hardware expected to keep your pool water spotless, warm and sterile.
Once the pump failed or most exceedingly bad, you can rapair.
we convey a wide choice of substitution spa and swimming pool pump engines.
So we have a alternate for replacement of that above ground pool pumps .
