i have a K48l2PA101A1 single speed, 48y Frame motor from a pentair whisper flow pump, need a motor and shaft seal as well as the O ring seals the gap between the motor and the plastic pump housing whis is approximately 2.5 inches in diameter.
Hi wldhntr01,
You will need either the QC1102 Replacement Motor or the USQ1102 Replacement motor along with the Gokit32 Whisperflo Tune Up Kit which includes all of the o-rings, gaskets and shaft seal for your pump. To determine which motor you need can you supply me with the SF, HP, Amps and Volts listed on your motor label.
SF 1.65 HP 1 Amps 16/8.0 Volts 115/208/230
I did upload a picture of the Tag last night to the Inyopools e-mail address as well
Hi wldhnter01,
Based on this information You will need the QC1102 Replacement Motor
