Bought a replacement motor and everything matches except the code.
My motor is type B code J and replacement is type B code K
Will this be a problem?
Stephen - The code being different is ok. The specifications that need to be the same are HP, Service Factor, Amps, Volts, Phase and Frame.
Check out our article on “How to Read Pump Motor Labels”.
