Replacement for Century Centurian AO Smith Motor & Parts
Need to replace our Century Centurian AO Smith motor… Finally died… Current pump motor specs include; CAT USN1202, PART 7-193687-02, SERIAL 307113M, TYPE CX, FR Y56J, HP 2.0 (Sticker says Powered by Total HP=2.40 AOSmith), SF 1.20, PH 1, HZ 60, RPM 3450 VOLTS 208-230/115, AMPS SF 11.0-10.2/20.4, TIME Cont, CODE G, INSUL CLASS B, AMB 50 degrees C… Also would need the Go Kit (salt water pool) seals, silicon and gaskets etc…
Thank you for contacting Inyo. The replacement motor is model USN1202. That motor is used on Hayward Northstar pumps. We do not have a salt water GOKIT for that model. There is a salt water shaft seal for models manufactured since 2003. That shaft seal would be part number 5250-250. For older models, before 2003, the salt water shaft seal would be part number 5250-235.
The individual parts can found on the part pages listed below.
Hayward Northstar 1998-2007
Hayward Northstar 2008-Present
