Pool Filter Replacement Element
Hello,
Could you please tell me if the following filter element would fit a Pre-fac Nautilus Model NSS-48 DE Filter?
https://www.inyopools.com/Products/07501352018474.htm
thanks!
Kathie
Hi Kathie,
Yes this DE Grid Assembly will work on the on the Pac-Fab Nautilus NSS-48 DE Filter
Hi
I have a Perflex DE filter model EC50AC, i am looking for a syn-flex fitting to replace the vent valve so i can run water to my sliding board. I cannot find the right threads, I bought a kit from the local pool store but the threads would not fit. Can you tell me what threads there are so i can buy a fitting?
Hi Norman14,
Below is an Image with Dimensions for The Hayward Perflex Air Relief it appears to be 3/8"
Thanks, do yhey make a 3/8"synflex fitting i can use to replace this fitting so i can run water to my sliding board? I tried buying a kit but it did not have the right size fitting.
Nothing that we carry or that is standard for the pool industry, I did find this Synflex Catalog that you may want to take a look through to see if you can find something that will work.
I’m looking to replace my cartridge filter with a 30 inch inground sand filter.  I have a 1 HP super pump.  Will that be sufficient
enough to rum the filter as intended
Hello Swimmingpool - Yes, you can use a 1HP Super Pump with a 30" sand filter.
