Pool components
I am installing a fiberglass pool (16,000 gal) and will be using Jandy equipment.  The pool will have a heat pump with chiller, water slide, 1 bubbler, 2 laminar jets, 3’ cascade, 3 led lights, 2 fire bowls and a fire pit on the deck.  I am not sure if I want to use a salt water chlorine generator so it will most likely use an inline chlorine dispenser.  I want to be able to control everything from an iPhone.  I will use the Aqualink RS controller.  I am not sure if a variable speed pump will be worth it with all of our water features, etc.  Would you recommend a VSP and what kind of power center do I need?  Remember, I will probably not use salt.
Hello Karateew - We would definitely recommend a variable speed pump for your pool. This pump can circulate the water on a low speed and provide additional flow to the water features on a higher speed. Also, the variable speed pumps are the most energy efficient option.
Listed below are the components you would need for the Jandy iAqualink automation.
