Need to replace motor on my Jacuzzi Magnum Force pump. Not sure of size and model needed. The label is all but destroyed from sun. Trying to use measurement guides on parts list but not quite working. 11" motor shaft 21/2", 7/16" bolt, but the back width appears to be like 61/4" which doesn’t match any. It is a 33000 gallon in ground with sand filtration.
Hi Horwillie1,
Is it possible for you to remove your impeller and supply us with the part # off of your impeller? This would help us to accurately determine your motor. Here is a Guide on How to Remove an impeller which you should find helpful. If this is not an option then could you post a few photos of your pump label to this thread, I know it is illegible but there may be a shred of info. that we could use to pinpoint your motor. Below is information on how to post a photo.
