Is there a color changing LED pool light that I can change remotely, or pick my own program? Looking for a retrofit application of existing pool niche.
Thanks,
Mo
Thanks,
Mo
Hi Mo,
Are you looking to replace your complete pool light fixture and bulb or just the bulb? Also do you know the make and model of your pool light? This information would help us determine if there is remote control option available for your set up. Also if you want to post a few photos of your light to this post that would be helpful. To post a photo follow the instructions below.
I.e., a smart bulb, similar to colorsplash.
The only option I’m aware of would be changing out your switch with an X-10 switch, here is a Video on replacing your light switch with an X-10 switch which you should find helpful. Here you can find some of the X-10 Pool Light Switch & Remote Options
Thanks, Patrick - that’s a great idea for controlling on/off/dimming (X10). But nothing for controlling the colors or program? I have no idea what the make and model of my pool light are. I am in the process of draining and reflling the pool. I’ll take some pictures and send over. I thought this would be a good time to swap things out, since I have easy access to the lights. The pool light is a big normal looking circle, with a bunch of screws around the outside, maybe 10? The spa light is about half the diameter, but looks the same otherwise. It looks like they both have some old-school incandescent bulbs.
Thanks for your help!
Thanks,
Mo
Hi Mo,
Have you had a chance to take some photos of your light? If so please send them over.
