Looking to repair son-in-laws 2 speed Jandy pump…PHPM 1.5-2. Serial Q08FK0651. Motor bearings shot. Don’t see a rebuild kit, so I’m looking at motor, shaft seal, diffuser / impeller hardware, cover gasket, and probably the big pump body o-ring (anything else?)! My question is this: by the time I get all the rebuild parts, it feels like I’m getting close in price to a new pump. But I don’t see the 1.5HP 2speed on your site…closest is 2.0 hp 2 speed. Do you have the 1.5HP, or would another series 1.5HP 2 speed work without having to repipe inlet and outlet? Suggestions…
Hello Aegerpa - We’d be glad to assist you. The replacement motor for the Jandy PHPM1.5-2 is model B2982. The replacement motor is a full rated 1HP with a total HP rating of 1.65. The total HP matches your 1.5HP uprated motor. The impeller kit is part number R0445303. This kit includes the impeller, diffuser and diffuser o-ring. The shaft seal is part number R0479400. The backplate (body) o-ring is part number R0446300. The cover o-ring is R0449100. Those parts will add up to slightly over $400.
We do carry the PHPM1.5-2. The cost right now $650.99.
Thanks! Got the parts in record time. Great online service, great parts service!
Thank you for you order with Inyopools.com!!
