I have a 18x33x54" above ground pool, approximately 15000 gallons. I live in Suffolk Co. New York and am looking at the 125k or possibly 140k heat pump. Is there a big difference or a recommendation. Also is there a specfic date when the sale is ending.
Hello Mulvey - We ran a heat pump analysis on your pool. We didn’t have all your parameters. We set the desired temp at 84° and a swim season between May and September. We also assumed you would be using a solar blanket. The recommended heat pump came back as Hayward model HP21004T. This is a 95,000 btu heat pump. If you want a higher temperature or are not using a solar blanket, you may want to consider a higher btu.
We receive price increases quarterly. We can’t guarantee how long the current price will remain.
