I’m looking to replace the pump motor on a Hayward super ll with a CT1102 high efficiency model (plus seal assembly kit). Will It fit my current super ll model below? Thanks
Pump model. SP3007X10a
motor model. C48kzn143b3
Hi Peter66,
For your Hayward Super II SP3007X10az you would want to go with the UCT1102 Energy Efficient 1 HP Replacment Motor as your pump is an Up Rated Pump. The UCT1102 is the uprated energy efficient replacement motor where the CT1102 is the Full Rated energy efficient replacement motor.
If your interested in learning more about Uprated and Full Rated Motors then it is covered in this thread: Motor Ratings
For your seal kit you will require the Hayward Super II Tune Up Kit Go-Kit2
