Correct Pool Pump Replacement
What’s the correct pump motor to replace the following motor
Serial #  8-186468-01
Frame: Y56Y
Type: CX
Code F
Form: KJM
HP 1.5, SF 1.1,  Amps: 7.8-7.4 / 14.8   Volts: 208-230 /115
Serial: BP2-21
Centurion SE for Anthony
Magnetek
Hello PerIverson - We’d be glad to assist you. The replacement motor would be model B2841. The B2841 is a 1HP full rated motor and your motor is a 1.5HP uprated motor. Both motors have the same 1.65 total HP.
If you know the make and model of the pump, we can recommend the seals.
pump
