Chlorina
Can the Hayward CL200 In-Line Automatic Pool Chemical Feeder be used with flexible hose
Hi Brian,
Yes you can use the Hayward CL200 with flexible, you may need to purchase an adapter for the connection. Will you be using flex pipe or the hoses that traditionally go with an above ground pool?
