Bottom Rims for Above Ground Pool
I am trying to replace the parts on my 24’ X 52" Artesian Monaco above ground pool.  The top rails are in great shape.  The wall has “Elite” written on the wall.  The wall is all gray hues.  I need to replace all 17 bottom rims as well as the brackets.  I am having a hard time finding the exact bottom rims.  I also need to replace 8 of the caps.  Is this enough of a description on what I need or do you need the pictures of the wall?  I have the wall rolled up so it will be a little hard to photgraph.  The description on my bill of sale states :Item # 2452-65-ST-SG Art Frame 6500 52" S. Grey Monaco 24’.
I forgot to add that the pool was purchased in 2005
Hi Cynthia,
Could you post a few photos of your pool to this thread.
  • One which is a wide shot of the pool showing the wall pattern
  • A close up shot of the top cap
  • A close up shot of the top plate
  • A close up shot of the top rail
Also, can you find any part #'s embossed into the pvc top caps and metal top? Many times the part # is on the underside of the top cap. All this information will help us find the correct replacement parts for you.
Hi Cynthia,
I did check with our above ground pool parts technician to see if he knows your parts without getting photo’s and we were able to get an identification the Monaco. The Monaco uses the 11313 Monaco Plate Single we also carry a 10 Pack at a bit of a discount 11313 Monaco Plate 10 Pack For the bottom rim you need the 11861 Monaco Bottom Rim You can view all the Parts for the 24’ Round Monaco Pool here.
