1 1/2 hp pump timer
Under an outdoor timer for a 24’ above ground pool.
It has a pentair 1 1/2 HP motor and I believe is on a 20 amp.
Hello Dmcavoy06 - We’d be glad to assist you. We do not have a plug in style timer for 1.5HP above ground pool pumps. Your motor would need to be hard-wired to a timer. For 115V, you could use the Intermatic T101R3. For 230V, you could use the Intermatic T104R3.
